ATI Damper
c.moo
1:28 PM
tennessee
Which damper to use on 440 , internal balance , for street ? ATI 917122E or ATI 917120E . Thanks
Depends if the motor is internally balanced or not. Likely "internal" but that's not a definite.
The 917122E and you’ll need to hone out the inner hub for the correct press fit.
If you are ordering new, make sure to get a BBC bolt pattern on the hub, much easier for buying all the FEAD drive mandrels components. Mine was still a BBM bolt pattern and I wound up making most everything custom for my front dress.
