I just started a stroker project on a 1975 400 block using a 440 source 470 stroker kit. After chatting with a few engine builders here are my 2 cents. The 400 block is stronger and will allow for slightly easier header clearance but if you go with TTI that doesn't really matter because they all fit fine. My 470 combo will allow for lots of street use without overheating issues, piston slap, etc., which is something to consider. The main problem with a low deck would be the intake options. If you just want a single 4bbl there are lots of options, but if you want to get into some "cooler" stuff like 2-4bbl, cross ram, or whatever the choices are limited. The engine builder im using has done quite a few low decks and actually competed in the engine masters competition around 10 times so I trust him when he says dont go over the 470ci kit on the low deck for regular street use. my original plan was a 500 or 512 because i simply liked the sound of over 500ci! but in reality, he said to save those ci for the RB blocks.
