Curiousyellow71
I can see why you getting frustrated...something is likely off in your compression numbers.
Using a 400s 9.98 deck height....the icons and 6.86 rods should be .007 below the deck. They are mid to high 8's w a 90 cc head and about 10.1 with a 74 cc head figuring with a .045 thick head gasket. If the piston were .18 shorter that is about 6:1 compression not 9.3.
My numbers are using summits compression calculater.
To accurately use the compression Calculater you need the head cc's and the head gasket thickness. I assume if your boosting your going to run cometic head gaskets? Imo..they are the only way to go.
