SOLD B & M Holeshot 2800/3200 Converter...................$450.00
GTX JOHN
11:01 AM
Boulder City, NV.
Feedback: 98 / 0 / 0
Here is a 10425 B & M Holeshot converter for 727 Torqueflite
Rated 2800 to 3200 RPM
Used about 2000 miles behind a 300 HP Mopar 360 Crate Engine and it
stalled around 3000 RPM. It was smooth and progressing and great (Very Streetable)!
It would stall a bit higher behind a Big Block or a Higher HP Small Block. It features both
5/16 and 3/8 Bolt provisions. This saves you the expensive of an expensive Aftermarket
Flexplate and new bolts. This is a desirable and not common feature on aftermarket converters.
This converter works great but has some minor wear on the Hub that is not
unusual once it is used. It sealed perfectly and did not leak. I did not polish the
hub and it is exactly as removed.
It is about $950.00 from Summit.
Because of the incidental wear which is very common I will sell it for
$450.00
Plus $37 shipping or free to Arizona So Nevada So California as i travel there
all the time.
It is very smooth and progressive. It locks up very clean
with minimal slippage and heat generation.
The new B & M generation of Converters are in my opinion
the absolute best for a Street/Strip compromise car! However, on the
other hand - they are probably among the most expensive.
However, as my Pops told me "You buy the best = You ONLY cry once".
The technology on converters has really improved over the last
decade!
PM sent
Sent you a PM
