best economical way to raise the rear end
i just bought new tires...and the speedo has been off since i bought it, but i thought that was because of the 391 rear?
Air shocks are out...i will look into adding a leaf.
Thanks guys. let you know how it works out~
:hello2::hello2:smart man........Artie:icon_thumright::icon_thumright:
That seems like a pretty good call. Do you disassemble the leaf pack, insert the new leaf and put it all back together?
Just removed the centering bolt, and any leafs shorter than the add a leaf. Put new centering bold in (comes with spring) Of corse you remove the U bolts too. The add a leafs are about twice as thick as the stock leafs, so you get a little stiffer ride.
Thanks for the info. I might try those soon. Are the ones in your link the exact part number that fits & you used? Thanks again.
I have been a carpenter all my life and i learn new things daily. i have had apprentices enlighten me to things i never gave 2 thoughts to. just because you been doing this for a million years dont mean you have all the answers. personally i would never put air shocks on any of my vehicles....but you go right ahead. i had a 1971 Monte Carlo back in 1982 (car was 11 years old when i had it ). the YO YO that had it before me put air shocks on it. now if you were ever in Pennsylvania during that time ..youll appreciate this. Yes they salt the roads here in the winter and it does nothing but eat the under sides of our cars ,,,,the road conditions were horrendous !....ANYWAY. due to this , new potholes would pop up daily...WELL... i hit one of them pretty hard and BOTH air shocks ended up in the trunk. i have been bitten by this and will never do it again. that car ended up in the junk yard as a result .....SOOOOOOO.... have fun with your air shocks!
Let's get a bit more scientific about this. Got to figure up what kind of forces are placed on the shock cross member when you go over bumps in the road. It's quite a bit actually but get a simple bathroom scale and place it under the car. The easier place would be under the bumper but then you have to figure in the distance it is from the bumper to the shock mounts and then do the math but for simplicity, let's use the bumper. Place a bottle jack on the scale. You can use a piece of plywood that's the same size as the scale surface just so you don't put a hole in the scale and ruin it. Now jack up the car 1" and see what the scale reads. 100 lbs maybe? Divide that by two and you'll have 50 lbs per shock. See where this is going? If you don't want to do the math, place the jack and scale under the area of the body where the shocks mount. If the upper shock mount cant take the stress, it wasn't installed very good or is rusted out. And what I meant about I've been doing this a long time, I meant that in all the years I've been messing with cars, I've never seen a busted shock cross member on a MOPAR but I have seen bent springs because of shackles. Yup, I'll keep using air shocks for that 1" more rise I want or add a leaf and no, I would never put air shocks on an Monte and longer shackles will never see any of my cars. Also, do you know how much more loading you place on the area where the shackles mount with longer ones? If the car is rusty enough for the shocks to go through and into the trunk, the shackles will most likely find their way into the trunk too. I'll be 61 soon and I started messing with cars in my early teens.....and I too have been a carpenter and come from a long line of home builders but got out of it when the economy went south and found a job that I knew would be there from week to week. PS, just because you had a bad experience with air shocks doesn't mean everyone else will....:headbang:
Find a spring shop to add a leaf spring under the main spring, this will stiffen the front section of the spring and prevent wheel hop. A spring shop can also re-arch the springs for whatever height you want. Doing this will increase the rear roll stiffness and make the car more apt to oversteer, so adding a front sway bar or higher rate torsen bars would be a good idea. Don't use air shocks. if you want really cheap and easy, use shackles.
The only drawback to re-arching leaf springs is that old springs have a tendency to lose the new arch rather quickly. Springs (all springs actually) get 'tired' after so many years of use so the best way is to get new springs or add a leaf to old ones.....
I bought some of these for my 67 Coronet, my new rear tires rub a little, I just need to raise it slightly.
How the heck do you get the new leaf in? My stock leaf springs are allot flatter, do you use the center bolt and also the ubolts to squish the new leaf together?
Thanks for any assistance
