Better Stopping
Gospel Runner
3:08 AM
CT
I have a 70 Roadrunner with drum brakes in the rear and aftermarket disc’s in the front. It still won’t stop. 1.25” Master cylinder, aftermarket power booster, with a separate vacuum pump and extra vacuum canister. It still won’t stop. What are you using to stop your hot rods? Any help will do!
If that wasn't a typo, an inch and a quarter bore master cylinder is gigantic. Holy crap....who chose that size???
The 75 Dart had a 15/16" master cylinder with power front disc and that car isn't that much lighter than yours. As bore size increases, travel decreases and the pedal gets stiffer. Even an 1 1/8" bore is likely too big.
I'm using 15/16" on my manual disc/drum on my '67 Coronet 4dr and it stops on a dime. My 110 pound daughter can stop it easily w no leg strain.
I agree with Kern, your MC is way too big. I run stock disks and drums, stock MC with several big cams over the years and never any vac/brake issues.
What Brand/model # Front brakes are you using ?
As said above, I'd bet your master is the problem. I'd go for the smallest bore you can find. And I'd get rid of the power brakes, I hate them, especially if you don't have enough vacuum for them.
I suspected that master cylinder was the problem. Yes it is a dual reservoir. Should I take out the booster and just attach the master to the fire wall? Can I use a master from a modern car, or so I have to stick with the old school style?
I'm not sure if you need the adapter plate going from power to manual. I'd get a modern 15/16 bore master cylinder that you can get from any parts store. If you need the adapter plate, Dr Diff sells them. You already have a power brake pushrod. The difference w Dr Diff is his are machined out to accept a manual pushrod.
Isn't SSBC belly up?
It lives still, it's under a different ownership
it did shut down in 2019, like a lot of businesses did
Covenant Harbor Lights Holdings, is the new or was the new owners
I saw/recently still listings for them on Summit
(I have their front brakes)
sort of long lead times to get products now
don't know much at all about the new owners
He told me that I need to buy his stage two front brake kit. He said it has a larger fluid capacity, and a larger rotor at 11.75”. I need to ask him if it is a two or four piston caliper, and what if any difference that makes. He has not answered my question as to whether I still need my power booster, vacuum pump, and canister, with this new set up?
[1] Removing the booster will make it even harder to stop.
[2] Contact the disc brake supplier & find out what size m/c they recommend for use with boosted brakes.
[3] If it is a smaller m/c, you will need a proportioning valve for the rear brakes because pressure will be excessive with a smaller m/c.
go to a smaller master cylinder , that will give more output pressure though brake pedal will be lower and softer . I removed my booster /pump combo due to it being a pain in the arse . Up to 127mph disc/10"drum was ok . After that not so much . I now have disc rear , GM type , pulls up pretty good from 131mph . This is a street strip 68 Satellite @ 3790lb race ready . Drives/stops great on the street and highway .
I have a 1 1/16 or 1/8 master
OH yeah , you will need a different firewall plate and pushrod if removing booster
Tex
You cannot just go to smaller m/c willy-nilly. The OP has fitted aftermarket front discs. These may have a larger piston or multiple pistons. That means more fluid displacement. A smaller m/c has less fluid displacement & without consulting the disc manufacturer about m/c size, a smaller m/c could bottom out....& not apply the brakes.
