The Horvaths
Thanks for the update.
If the 1/4 to 1/2" pedal push/hold won't let it start, it is one of two things (most likely). Fuel or spark. Do you have an insulated spacer under the carb? Is the fuel system routed so that it avoids heat zones?
Could the coil or ballast resistor be suffering from heat-induced intermittence?
