Big Block Intake Manifold-B Engine
Saeed-Sr38
New Member
12:34 AM
Iran
Hello every one
I have a 400 engine and I have to change the intake manifold
I can't find the correct part for my engine in Iran,but I found an intake for 383 B Engine
Does the 383 intake fit to 400 engine?
both engines are B-Blocks
All the low deck B Block intake gaskets are the same. 361-383-400. Other than there is one that has the passage for the heat riser blocked off. That is the one I use. Helps the manifold stay cooler.
10-4,
as daredevil and Gary said,
361, 383, 400 all use the same intakes
