Looking for some guidance, ( in pictures) for the correct looking blackout treatment application on the front of the radiator support, behind the grille, on a 65 Bell II. Thank You.
Great pic! Thanks Much!
Thank Youfor paint I've used SEMS trim black .
Ahhh Woodward Ave Garage We Were The Ramchargers! GREAT BOOK!!Looks white in this pic.
Thanks " Kid "! Same color as our 65I know this isn't a '65, on my '62 it looks like they used a rattle can and hit it lightly.
It's called "Shell Beige" on the '62. It might be a shade different on a '65.Thanks " Kid "! Same color as our 65
Actually yes .. XX-1 Light tan. Wife calls it " Grampa Car " We"ll see about that!!It's called "Shell Beige" on the '62. It might be a shade different on a '65.
Question to You "Kid" ... Reading all the manual disc brake conversion skuttle...I gotta make my move for a purchase. Front mount calipers cause interference with (intended sway bar). The more I read, the more I Waffle. Respect your take! ThanksIt's called "Shell Beige" on the '62. It might be a shade different on a '65.
I'm having the same dilemma on the disc brakes.Question to You "Kid" ... Reading all the manual disc brake conversion skuttle...I gotta make my move for a purchase. Front mount calipers cause interference with (intended sway bar). The more I read, the more I Waffle. Respect your take! Thanks
Spend a lot of money or just use what works. I like the idea of useing mopar parts that you can go to the local parts house for replacements. I'm leaning towards "right stuff", rear mounted, slide type calipers. I believe as long as you are useing the rear mounted caliper, there shouldn't be any problems with useing a sway bar.
Correct me if I'm incorrect.
THANKS FOR YOUR HELP 65 HEMI !
