sputnik 440
Capt Jim
Personally I would swap the rubber out for steel. I have steel lines to the (mechanical) pump and from there to the carb. Factory routing, factory HiPo manifolds. I only get into (heat) trouble when my temp climbs higher than about 210°. Which is rare.
Also, if you're running any percentage of Ethanol you're going to be very sorry running that much rubber line. It will it it like pigs at the trough.
Steel lines also will not trap the heat as rubber will.
Thanks Lionized...good points on the ethanol. I always fill up with the good stuff, but good stuff is not always in the station's tank. And, you are right about the lack of heat dissipation from the rubber. It doesn't want to heat up as quick as metal. What goes up fast, comes down fast. Steel transfers heat 10 times faster than rubber, while steel only holds 1/4th as much heat energy. It would seem to make theoretical sense to go with a material that will not transfer the heat it holds, into the gas going through it. Now, with all that said, I will be opening up the web to find a metal replacement for the rubber. My reason, It Looks Better. Might as well get rid of the inlet tube. I think they are only 5/16' coming down from 3/8" anyway. Any suggestions on that? Might as well move the filter to the upside of the pump and put a new gauge in front of the inlet line. I bought a mid price range one ($30?)with fluid in it and don't really like it. I would think the fuel would like coming up the front of that path better than running along the fire wall. A lot shorter distance and less time to pick up heat. Any suggestions on who to purchase the "stuff" from?
