67GTX440
Is a proper bolt/nut/clip etc. guide for a 67 GTX available anywhere? I have a service manual, but not a parts manual. Is this in the parts manual? Is there also a body manual? Is this in it?
Also is there a reference that shows the proper side sill hole spacing for the 67 GTX? My body shop put on full length patch panels on both sides and I lost all the holes from the door back? Not sure it makes a lot of difference as long as the holes are in a straight line, pretty equally spaced and the one one just behind the front wheel and just in front of the back wheel are pretty close to the end of the sill molding. When I pulled these off, the front ends were siliconed to the body for some odd reason. Are there 8 total each side?
I want to make sure the hood scoops are reinstalled with all matching studs and nuts, but $79 plus shipping for the set from RT Specialties is pretty steep. Anyone know where I can find just the individual studs and nuts what I am missing? Does a sealer go under the edges of the scoops where they meet the hood? What prevents paint on paint rubbing?
Everything I have taken apart on this car has been apart before and it seems that all the proper hardware was tossed upon disassembly and reassembly done with whatever could be found at the time that was close.
The joys of trying to trying to bring a car back to spec that has had an unknown number of owners over 47 years!
Thanks!
Thanks!
