stushug
Were you able to tap the shaft back out while the column was in the car? I assume if you did, you had to remove the steering wheel and work from that end. Correct?From what I recall, The steering column center shaft was redesigned for the 1967 year. It became a hollow tube within a tube that would collapse on impact to prevent a Shish-K-Bob. When these columns were built, the length was set with the tube within a tube and hot plastic was injected into a channel to keep the two tubes connected but still able to collapse. Over the years, the plastic can get brittle and allow the tubes to move around a bit.
I wrote about this in my Borgeson installation thread. Somehow when I pulled the column out, I pressed the coupler rearward a bit and the tube within a tube compressed. I simply tapped the shaft back out to the point where it all fit together correctly and called it good.
Regarding the centering of the steering box, I simply put a line on the splines and kept it still as I slid the coupler on the input shaft.
