Borgeson
EARLY B
8:21 AM
ALLENTOWN,PA
Can anyone tell me how to remove the valve section from the 800126 box? This is the part that the lines are connected to, the part is held on with 4 bolts. Will this just pull off over the steering shaft when unbolted. Is the any rebuild instruction published anywhere? The internet returns no info.
How about ringing Borgeson or their agents?
I could understand asking a forum if it was after hours and you needed an urgent answer but after a month? Call them.
And you think that you could find a schmatic of the box on the net. Or simple disasembly instructions.
Not sure but I would bet there is a snap ring that would need to be removed from the shaft before it comes apart. Why are you taking it apart?
I thought I read years ago that the Borgeson gear is based on a Jeep gear of some sort. I would contact them for a parts layout or send it back for repairs if needed.
Thanks for all the replies. Now that the cruise season is almost over, I will try the disasembly and find out how this works. The reason for the removal is that I have read that this area is ported for better flow of the box.
Thanks.
