Hi everyone! I'm kind of at my end with this brake issue.. I have researched, looked in fsm's, asked several people and don't seem to get a good answer as there aren't many people around here into mopars?? So, why not ask here where the mopar guys are!
Info - 1969 Charger 383h previous owner installed
Wilwood disc all way around with mp brake kit bm1306
I changed the cam to a more Mild cam but little vacuum. Last check about 11 inches (but haven't checked since put new msd ignition and tm6 intake on. Just had first road check Sunday. But it was short as brakes sucked!!
Master cylinder leaking where connects to booster. Brakes have been issue from day 1 as po stated that due to the cam, vacuum was low so brakes didn't work. He had an electric vacuum pump on it which still didn't make things any better. I removed it and actually brakes were same, which got me thinking the issue wasn't all vacuum. That was when I noticed the MC leaking. Obviously, the system is not original so the FSM doesn't really help me much. I have been told to go manual brakes and do away with the booster all together. I have been told just replace the MC.. I have seen many people recommend many types of MC's some work some don't. I do understand that a lot depends on the rest of the setup too!
The car is not original, nor will I be trying to get it there so
I guess my question(s) would be:
Stick with booster and replace just MC
Or go manual?
Which darn MC would be the best to go with? I don't really want to drop a lot of moola trying to find one..
Thanks for a place to go and ask for help!
Or go manual?
