Brake rotors
RS23VOA
7:26 PM
Virginia
So i'm getting close to needing brakes on my GTX. What brand rotors is every using? I have a decent stock set but would prefer a new set.
only buy a good brand and made in north america not off shore
Most of the older mopars I have done the 73 -up A body style disc brake swap on. I just used rotors from napa to replace them. I can also say I put a set of drilled and slotted rotors on my Dodge diesel from summit and I have really like them. That might be an option if they offer a rotor for your application. Best of luck.
Matt
Stay away from "made in china" If I get one from a parts house I tell em to keep it! All the ones Ive ever used end up with some warping in about 1 year or so. Used are best if they have anything left to cut.
+1 for mattsmopars. I just replaced the front brakes on my 74 charger. Used Napa brake lines and calipers, summit drilled and slotted rotors, and Bendix ceramic pads. Very happy with them so far.
If you have never used thiem before......just be aware that drilled/slotted rotors will typically cause high rates of pad wear in moderate to heavy use.
I have the 1966 - 1969 4 Piston Caliper FRONT DISC BRAKE ROTORS -- there is NO China for these...
I have the 1970 - 1972 Front Disc Brake Hub & Rotor Assembly -- 1 piece N.O.S. U.S.A. made
(yes the new china version is garrrrrbage....)
The 1973 & up Hub & Rotor ---- sadly is ---- all ---- china made -- and that's the rotor on all the disc brake conversion kits....
I do have one (1) only -- O.E.M. 14590 Kelsey-Hayes HUB & ROTOR Assembly for the '73 & up!!!!!!!!
ALWAYS BEST TO CALL ME --- Craig -- 516 - 485 - 1935.... New York.....
Oh, P.S. ------
I also have some ++++ N.O.S. ++++ Asbestos Brake Pads for these applications !!!!!!!!
If you truly want the ----- VERY BEST ----- brake pad on the planet --- they be the "MEN"!!!!!!!!
It is not illegal for us to transact on them, do not fear -- they are N.O.S. and the satutes allow
for the fact that they were manufactured before all jurisdiction.....
CALL ME ----- Craig -- 516 - 485 - 1935.....
