jz61
so im at wits end! my 65 belvedere has a disc brake set up from a later model, im guessing 68 to 70 b body. its a manual system, dual master cylinder. all was fine, the one day pedal goes to floor, pump it up , seems fine. so o change the master with a new not rebuilt unit. bleed all brakes, all line look good, no leaks, not a drop of brake fluid any where. seems good, then pedal right back down to floor.WTF! start to check things out, seems the problem only happens when I turn the wheel almost to lock either way. as soon as I straighten wheel ,brakes pump rite back up, you can stand on pedal all day, firm and does not loose pressure! jacked car up took front wheels off got under car turned steering back and forth looking for kinks, pinches, leaks, not finding any thing. I car hear when steering goes past a certain point,air bubbles in the master, while wheels are turned one side or the other, can not get pedal pressure, as soon as steering comes back to center pedal will pump rite up and hold pressure! have new distribution block,and was thinking of running new lines, but I don't think that is the answer, as I don't see any evidence of leaks or loss of fluid. im thinking its something real simple that im just missing any help from anyone who has had similar problems would ne very helpfull
