Not that was grabbing my attention, cleaned it with brakecleaner and a wirebrush, did not swap the brakepads.. guess I just have to pull everything again. Serviced it all when Installed Aeroflow Line lock on the car - manual 4speed. All the brakelines and brakehoeses, new also. It worked great before I serviced it all, installed the line lock for easier burnouts on sticky tires.Those look correct.
Do you have any ridge on the inside edge of the drum where the shoes run?
If so take it off with a file or grinder.
Should the green spring be in the bigger hole underneith? They work flawless when I bleed and test brake with the wheels in the air, but when I go for a test drive it won't release after breaking.The green spring is in the wrong hole. When you say lock up what exactly do you mean? Skids or wont turn? Are you sure the rear are working?
Did not grease those spots, maybe I should?Did you lube the contact points where the brake shoes rub on the backing plates?
The smaller hole behind the adjuster screw.Should the green spring be in the bigger hole underneith? They work flawless when I bleed and test brake with the wheels in the air, but when I go for a test drive it won't release after breaking.
Okay so the longer end off the spring goes behind the adjuster. Did not have the auto adjuster on before, was only a shorter but much "beefier" spring over the adjuster screw earlier alsoThe smaller hole behind the adjuster screw.
No did not replace the Master cylinder. It stops great just wont release like it did before I replaced all the stuff.Did you replace the Master cyliinder? I'm wondering if it is not releasing all the way. When the brakes are locked up, try loosening the master cylinder from the firewall to see if they release. If so, you will need to shorten the push rod some.
Sounds like a hydraulic lock up to me. Something in your mod may be off
Yeah that's what I was thinking but cant figure out what causing it. I hear it locking and releasing when I push the buttom. If the car sits for a longer time the break pressure fade and the car roll on it's on again in N.Sounds like the line lock is the problem.
To me I would just bypass the solenoid and see what it does. By some chance is the solenoid marked in and out?Maybe I should take off the little "T fitting" they want u to add and just mount it between the Master and the pressure block
Yes, it's mounted as shown up. Brakes probably works fine if I bypass it but I want the line lock on sticky tiresTo me I would just bypass the solenoid and see what it does. By some chance is the solenoid marked in and out?
How old are your hoses? With old hose the internal lining will separate from the outer, and when you hit the brake that inner hose will collapse and not release because of the vacuum created causing a lock up condition. AMHIK Good Luck
You need to try something and that is the most logical. If they work ok after bypassing the solenoid then there must be a defect in it.Yes, it's mounted as shown up. Brakes probably works fine if I bypass it but I want the line lock on sticky tires
