So I'm thinking about my next build. I'm thinking either a early Ford Ranchero or a Dodge Rampage. It'll be a small block v8 auto/OD. So the goal would be 25-30 mpg. I chose these two bodies for being smaller and lighter. I can make either one work. So the meat of the question is how to build a highly efficient engine. So I'm wondering if anyone has any ideas or experience on this type of a build. I was thinking higher compression would be a benifit. Roller cam to reduce friction. I would like the peak efficiency to be in the 1750-2250 rpm range. I'd likely be using a newer OD trans with a lockup convertor. Now for the kickers, I'd like to keep it carbureted and keep it as simple (as few electronics as possible). Let the discussion begin.
