383man
not the same sending unit, on a 68-70 RR, GTX, Satty, Belve., but a photo of the extra line/fitting going back into the fuel tank, via the sending unit fitting bungs/nipples...
If you plan to use that vent line on the sending unit I would make sure it does not go over to the filler neck. It looks to me like that line goes about an inch or two into the tank and then bends 90 degrees which makes me think it may be the vent to the filler neck ? Once fuel covers it the filler neck wont vent anymore and the pressure will kick the fuel nozzle off at the pump. I may be wrong but I would check it to be sure. Ron
