Went Diehard on my 72: Johnson controls makes a great portion of batteries any more: did NOT go gel, dad had gels in his 92 motorhome, they literally exploded, went back to old acid type, rather add demineralized water then blow up battery: 9 & 16 years?? THAT is unheard of, 4-6 at most, even if car sits, got your money's worth for sure. Forgot your RR was street/strip car, different electrical setup: Change battery, throw a 2 amp charge on it for 48 hrs, check battery voltage, 13.1 + volts, install and then see what you have: SUPER CLEAN/SHINY connections, any "green" on battery wires, not good: maybe check ohms before hooking battery up to ensure good continuity between battery wire & alternator and starter (high ohms =voltage loss) check ohms across trunk shutoff too.
