1stBxMopar
Does anyone know if the cat fluid damper will work with stock pulleys on a BB 440 ?
With the proper shims/spacing they will probably work OK, most all the aftermarket Harmonic Balancers/Dampeners you need to either, shim the pulleys or shim/adjust the accessories to, match the pulleys offsets, pretty common on these Mopar engine builds, nothing just bolts up like stock "usually", because of different thicknesses of the Aftermarket dampeners from the stock one, if you going for performance applications maybe go to, March Industries, get some aluminum pulleys, they can free up some HP, keep the belts on better at higher RPM's, plus lighter &/or smaller diameter, plus they look allot better also...
