- 4:07 AM
- Apr 13, 2012
- Granite Bay CA
For anyone with a 73-76 A body, 70-74 E body or any 70-72 B body, I have a way to save several bucks while getting the largest front sway bar that will still fit through the k member.
I have a 70 Charger. It HAD a 1 1/8" Addco front sway bar, but I wanted bigger. The only vendor that I found listing a 1 1/4" solid bar is Firm Feel. I'm sure that they have great products, but I wanted to save a few bucks. Sure, sometimes these efforts bite me in the ***, but this time it worked out.
I went to the junkyard and pulled a 1 1/4" front sway bar from a mid 80s GM 2wd 1 ton truck. At home I laid the Addco bar atop the GM bar , then cut the extra material off of the GM bar. I tapered the ends and had a guy in a shop drill holes in the ends for the end links. Total cost for the "custom" bar: $33 for the bar, $20 for the bushings and $17 worth of Coors beer for the guy at the shop.
The GM bar isn't a mirror image of the Addco bar, but it fits. The 1/8" difference doesn't sound like much, but using the math formula to calculate sway bar rates, this tiny increase results in a 30% stiffer bar!
Using a front bar this large would lead to MORE undertsteer if not paired with a larger rear bar, so I'm REinstalling the 7/8" bar I had before.
Do it to it.:headbang:
