SUPERSTOCKRACER
I'm finding that the hole size in the back of my 8 bolt Callies Magnum crank is tighter than I remember, when putting the torque converter pilot end in when installing the transmission.
I put grease in the hole and on the pilot end of the conveter prior to assembly.
Do you guys, do any clearancing on the crank or pilot hole prior to installation. Seems very tight and I don't remember this ever being an issue before. I tried 3 converters and all 3 are tight going in.
I think after the grease heats up , and falls off, the converter is going to be a bear coming out.
