Kozlow
HI,
I am trying to degree my camshaft, but I have a problem.
Cam lobe separation = 110 degrees
The cam has 4 degrees of advance ground into it.
I have the timing chain gears at 0, no advance or retard.
I want to install cam center line at 106 degrees.
If I check the cam center line .050 down from high point of intake cam lobe on either side, add the two locations together, divide by 2, it checks right on at 106 degrees.
But...
Then when I check the opening and closing location @.015 as per cam card, the cam checks 2 degrees retarded. Which puts center line @ 108 degrees.
So,
Is it better to run as is,
or
Advance the cam 2 degrees?
If I advance 2 degrees, and check .050 down from the high point the cam, center line would be @104 degrees. But the opening and closing locations would be correct to cam card and center line would be at 106 there.
It seems like the opening and closing would be more important.
What you think?
Steve
But...
So,
or
What you think?
Steve
