747mopar
I wanted to get some feedback on cam selection from you guys, I'll be pulling my motor soon to do some paint repairs and thought if I'm going to change anything now's the time. The motor is a 456, 9.8:1 compression, ported 452 heads that flow up to .600 lift, Eddie RPM intake, full length 1 7/8 headers and a Mallory ignition box. I selected the cam with cruising in mind but have often thought about bumping it up as it's very mellow, here's what's in it. I might also add that I'm switching to a standard as well that will put cruising in the 2,000 rpm range.
Comp Cam 21-230-4
1,800-5,800 rpm range
110 LS
106 centerline
Int lift .488
Ex lift .501
Int duration 268
Ex duration 274
Right now the cam is the cork so my questions are.....
#1 How much can one expect to gain by going up to the next size up?
#2 Because of the Cubes (torque) are these motors more forgiving on bottom end when running larger cams?
I'm all ears to anything you have to suggest, Thanks
Comp Cam 21-230-4
110 LS
106 centerline
Int lift .488
Ex lift .501
Int duration 268
Ex duration 274
