generaljmwlee
383 engine stamped-2468130.8 1-28-69
heads 2843906-6
did i miss any numbers on the block or heads?
heads 2843906-6
there is a -6 at the end of the head number thereis another number that is 02059on the heads are those heads 906 heads and if so are they good heads or hi-po heads?
The extra 6 is a lot number isn't it?
there is another number that is 02059on
since the heads casting match nice to the block I could assume they are orig to the motor?
The -* number at the end of block and head castings indicate which casting core revision was used for the heads. As blocks and heads were cast, the mold would shift over time so a new mold had to be used. When the mold was changed, the -* number was changed.
This is your casting date code.
02= February
05 = 5th day
9= 1969.
This casting date would fit very nicely with your block casting date of 1-28.
Your engine assembly date, stamped on the front pad, is probably about a week after the heads or around the middle of February.
The VIN is on a pad on the passenger's side of the block, about 1/3rd of the way back and above the oil pan.
HP and non-HP bare blocks are the same. The long blocks are what are different and merit the HP stamping.
Unless all 13 digits of the VIN are stamped on the block, like early 69 cars, it's almost impossible to know what the engine came from. You can narrow it down by knowing which plant the car that originally recieved the engine was built.
ok got more numbers off the block, under dist E383 2 18 2 R
on pass side 9F219773
Special Camshaft
Carb with 750cfm or better
10.1 compression pistons/connecting rods or better
this is a start
For your sake reserve the sarcasm for a rainy day.
Take it easy tough guy...I was just kidding around. **** sakes, can't even joke around with you. :sad:
Hey, hey I understand now. This is the computer world, we don't know what eachother's intentions or emotions are so there are breakdowns in communication.
