pedal2themetal
Hi All,
Working on my 75 Fury.
Slight problem .. I re-ran the purge line. I put it into the air filter housing, but I am getting heavy vacuum in the tank when taking the cap off.. the cap does NOT say vented.. it does say take off slowly due to possible fuel spray. It is a new cap install by a shop and maybe its the wrong type?. I am afraid I am causing excess vacuum for the fuel pump to pull fuel.. Should I get a vented cap? or is the canister plugged (canister only has 2 lines on it one from tank other (purge) to air filter)? When looking one up on AutoZone it says vented..
Only 76,000 miles on the car.
Thanks All
Tim
Thanks All
Tim
