67Satty
Well, I was joking in the part about driving it 50 miles to the track with 4.86 gears.  Guess that smiley I put there wasn't clear enough on that.  Sometimes my humor doesn't translate well online I guess.
But...wouldn't going from a 3.91 to a 4.86 in a heavy car knock some tenths off my ET in the 1/8 mile? Isn't the idea for the lowest possible ET to cross the stripe in top gear at the same RPMs (or even a little more) than where you make max HP?
Right now with 3.91s and a 27" tall slick I'm barely getting into third gear at the end of the 1/8 mile, so I have to be leaving a lot on the table ET-wise, right?
1/8 mile gearing calculators aren't easy to find, I think when I did find one once, it said 5.38s were the perfect gear, not that I would ever put those in.
I can't really compare my car to yours for what gear is going to work because I'm guessing you have at least another 100-200 HP over me with 500-600 pounds less in weight. But if you've run a 3600-pound or so, 425 HP or so car in the 1/8 mile I'm all ears about what worked for gears.
