Rockett
4-speed: I can't get my shifter to the left of the "H" pattern, so as to push it up into reverse gear. (It *was* working fine!)
All other gears are shifting fine. But I only have H rather than '-H
I looked underneath & everything looks OK ...no obvious damage or interference on the linkage. In fact, it seems like when the shifter is in neutral, I can manually move the reverse rod & lever (under the car) and it sounds like it clunks into reverse.
FSM has a procedure for "Gearshift Linkage Adjustment", but they show a special tool ("Lever Aligning Tool") that holds the levers in the neutral cross-over position at the "control mechanism assembly" (where the shifter does its magic). And this procedure simply adjusts the length of the shift rods.... but my problem seems to be that I can't get far enough 'left' while in the neutral position, so as to grab reverse.
Any ideas?
Any ideas?
