Frustration
Good luck. Most successful sportsman racers race by looking at the bottom bulb only. That's why they call it "bottom bulb racing". One thing you may want to try to eliminate going red...Add a taller front tire, or add more air to the current tires. That will increase your roll-out. The other item is stage as shallow as possible. Hopefully you're doing that already. If not, try it. It's the only way I know of to be sure how far from the starting line you are while staged. If you still go red, try to take a bit of RPM out of the launch RPM! Let us know how it goes.
