Ranger16
Is this a resto or a survivor?
it's a survivor.Is this a resto or a survivor?
We checked the 3 connection blocks - all clean...nothing burnt or broken...but you always wonder about 50 year old wiring...I thought the same thing...too much heat affecting the connections there.I might have missed it, but I havent seen where you describe how its shutting down, spit sputter or like the ignition was turned off like @Dennis H asked???
If its instantanious like the ignition being turned off, 99% sure it's electrical. Electrical components/connections are affected by heat and can cause gremilins as you have described. If your electric fuel pump is wired into the switched side of your fuse block it (problem) can be 2 fold. Switch or bulkhead connections are loose/bad, when they heat up, the contact required is broken....the heat is created not only from ambient temps but the amp draw, the less contact pressure you have causes the amps to increase which causes even more heat until the circuit opens. When it cools down it will have enough pressure to make the system act normal until it heats up again.
it's a survivor.
?Is it like someone turned off the ignition and threw the keys out the window? Check bulkhead connectors. Gently. Or does it stumble first. Get a digital temperature gauge to be sure of temps.
