miller
Not sure, Ron, though that kinda sounds like the box took some heat. Usually, that epoxy is pretty tough stuff. Maybe old age?I don't like the look of the back as the epoxy has partially separated on one end...
Well guys regurgitating my old post here as I'm still have the same f-ing problems again; but seemed to subside for awhile now back with a vengeance. Right at this moment I'm supposed to be in a cruise and later a show and be damned if tonight is actually nice around here for once. I've checked everything that is 'supposed' to be suspected culprits and all check fine! Ig switch good, ballast good, and put another on for good measure. Wiring all looks fine/connected. It's a new engine harness in the car for about 16 months now and had run fine. My guess right now is the ECU...I installed a 1st gen mopar electronic ignition some 15-18 years ago and this is the 2nd box. I had replaced it after doing all the checks and finally put in a new one and car started right up (it had been a no start issue then). So wondering if I should put in a 3rd box for the 30 bucks as all else seems to check fine. I don't like the look of the back as the epoxy has partially separated on one end...no clue if this is any issue as I've been grabbing straws at this point. Frustrating as the 99% culprits are ruled out. I'll add, since my car is a button shift, it seems to rock as if needing an adjustment; but hell I had that before and didn't cause this problem...any advice is appreciated.
It's maybe 10 years now on this box; car only get's driven maybe 4-500 miles a year and sits in a heated garage. It's been through a complete engine rebuild and new wiring harness now. Who knows, replacing is cheap even though I have doubts that's the problem...last time I kept hunting down an ignition problem (different symptom though last time) it ended up being the box.Not sure, Ron, though that kinda sounds like the box took some heat. Usually, that epoxy is pretty tough stuff. Maybe old age?
Did you look the wire from interior side of bulk head? Once had a wire pushed out on the inside when I plugged wire in from engine bay. The plastic that holds connector may have failed.I appreciate it when we share tips or get them to let everyone know how the problem was solved so wanted to let you know finally found the problem FYI. Some of you hit on it and I didn't take the tips far enough best I reckon. The top harness plug-in to the bulkhead was the issue. A buddy helping me out can take the credit, as he had a brainstorm while we were tracing down the blue wire to the BH. He held the harness up a tad while I started the car and fired up just fine. My issue is I have a new engine harness but a **** old BH. So shimming the harness plug to at least secure it has done the fix. Someday hope to replace the BH but at least working now. Thanks much for taking your time to toss me the tips!
