Sweet5ltr
So does a 4 barrel?
. . . Thanks for pointing that out . . . I had no idea . . .
They both have jets too right, just want to make sure!?
Fact is, you need a wideband setup to tune properly, regardless if it's a single 2-barrel on a 318 or a 3x2 setup on a 440. Bypassing this step is the reason 90%+ of the population can't get a carb to run right on the street, with their exhaust smelling like a raw fuel sewage pipe at idle, getting 6-8mpg, and smoking a piston after a few WOT passes. Of course, it's the box stock' Holley or Eddy carbs fault right!? A dyno operator is not a god, he uses essentially the same device to tune carbs that you can purchase for yourself for around $200. If you don't believe in these types of Voodoo' witchcraft devices, just go EFI with a FItech system and let it do the tuning for you based primarily on your target AFR (Hint, hint). . . Or stick with a box stock carb and hope for the best, good luck!
