Root2812
Hi guys... First I want to admit that I know nothing about 4 barrel carbs. I have rebuilt the 1 barrel on my 1950 Chevy and the one on my lawn mower but that's it. I hope you guys can give me some advice.
My car is a 1974 roadrunner with the HP 360 4 barrel. I believe the engine to be original but I am not sure. The carb appears to be from a late 70's truck I think. The numbers I found on this Holley carb say its a 650 cfm and the internet says it was a quadrajet replacement on late 70's trucks.
I dug up this schematic (page 5) online so please reference it since I don't know what anything does I'll just list the number on the picture.
http://documents.holley.com/199r8340-1rev.pdf
My car runs ok now but its symptoms always change. I know it sat for the better part of 5 years before I got it. First it started and idled great but was kinda a dog. Then after my dad screwed with some stuff on the carb ( think it may only have been the fuel level check plug) it didn't idle as well but it hauled ***. Coul it have been trash in the carb? My choke has been sticking too so I am sure that's a problem. I was looking it over and found a piece of linkage was missing (part 22) that pushed a thing down on the carb. I am not sure what this is and have no idea where to find one.
Also if you look infront of that part on the carb there is a small tower like thing that is one both the front and rear bowl. The carb is leaking out of the top of both of those. Someone at some point put jbweld or something over them to stop the leak but I stopped the leak with a duel resistant silicone.
Please help me figure out what to do.
Also If I bite the bullet and but a new carb I was thinking of getting Edlebrock. I want good power but also good drivability with my 3.55 gears. What cfm would you all recommend? 600? Also is this a spread bore carb? Then there are a bunch of option that I don't understand like mechanical or vacuum secondary's, choke type, ect. I think my choke is controlled by a spring or something in the manifold so is that manual choke or no? I know its not electric.
Thanks Guys. Sorry to be the guy who knows nothing.
