Carb question
peterpelley@eas
New Member
3:19 AM
Springdale , NL Canada
I have a 75 chrysler 440 installed in a 60 dodge panel van. It has a carter tq and i purchased a holley 770 avenger for it .The bolt pattern is different , the holley holes are 1" wider than the manifold holes on the stock dome. Is there an adaptor plate available for this application?
The adapter will make the carb sit higher, which can cause other problems with air cleaner and/or shaker hood clearances.
You may have to use the TQ until you can find a 4160 intake manifold.
Was the shaker hood an option on a 1960 panel van?
Mike
