Carb
goosebags
1:11 AM
Omaha
I have a 383 69 roadrunner. The car is an N96 car and right now it has a thermo quad carburetor. I was hoping to replace the carb with a more modern unit but also want to retain the N96 set up. This maybe a dumb question, but are there any modern carbs that will allow me to do this? I would also like to replace the intake. Was thinking about going with the M1 intake from mopar performance. Does anyone know of any fitment issues with hood clearance or the N96 setup? Thanks!
The Edelbrock AFB is a good replacement and should not give you any interference with the Air Grabber. The M1 dual plane is basically a copy of the stock intake so it should fit just the same, but I doubt you will see a noticeable increase in power.
