I second this!Pump arms are adjusted nice and tight?
When your car is off, look at the linkage for your accelerator pump(s). When you even START to move the throttle the tiniest bit, the pump arm needs to move. If there is any slop in it whatsoever, you will have a stumble.
If you haven't already, make sure your linkage is correct first, then start working on other carb tuning elements.
