- 2:16 AM
- Dec 21, 2021
- Miserable Smells TX
So I understand the function of the metering rods, vacuum controls them, I was thinking if you wanted to delay, you go stiffer, not weaker. But it makes sense that’s not the case. When you put the stronger spring in it, makes it open quicker, because the strong spring doesn’t require as much vacuum. When you put a lighter spring in, it has to fight the vacuum more.
(I understand the concept, but I may not be explaining it correctly
