85Bears
Hi. I just purchased a 1969 Charger 440 - it has power steering. I noticed the center drag bar is rubbing on the oil pan.
I replaced the oil pan w a stock 5 quart and when I went to put the center link back it still rubs.
questions...
1) Can someone please send me a link to buy the correct one?
2) Is there a difference if I 180 degree swap the bar around? I only took off the passenger side (idler and the other bolt) and swung it to the side to get the pan off. If I swap the ends could that be the issue? If I disconnect the driver side now and put it on the passenger side will that make a difference? Maybe it’s installed wrong?
help please
questions...
help please
