How about a claw swing- press??
Didn't use the freezer just put my propane torch on it for a while then it just fell right off with light pulling and the new one went on with no issues after heating too. And pullers didn't work busted 2 pullers trying to get them off before I remembered heat should workI’ve heard that you put alternator in freezer, heat pully slip it on. I know this will generate some laughs, but it works..
That's pretty cheap even if it needs a new jack....One “nice” thing about this next planned economic downturn is used tools are cheap again. I’ve just seen a 20ton on marketplace for $50
IMO.....the sheave (aka pulley) is an interference fit on the shaft with out a key. A jaw puller pulling from the end of shaft ( actually reacting on the shaft end with the jaws around the sheave'pullimg groove). To put the sheave back on and positioned correctly, it is pressed on....with a 0,0015" - 0.002" interference fit. The alternator must be disassembled exposing the brush end of the shaft and brush end bearing...the wiring does not need to be removed, but this would be an excellent time to replace the drive end bearing (#6203SZ sealed both sides single row ball bearing...any brand...SKF, NTN, RBC, etc). Support the alternator assembly with the he brush end bearing's shaft on the pressing plate, and starting the drive end shaft and sheave facing the pressing ram, slowly start to press the sheave on the shaft, making sure it's square. Continue to press the sheave to the required depth as measured AND RECORDED b4 pulling the sheave off from the shaft end to the measured ID depth. The shaft absorbes the pressing forces not the aluminum housing or bearing. This way the pressing on dimension can be controlled rather than heating the sheave and trying to guess the exact position b4 it cools off.What is the best way to put one on? Did one years ago by heating up the pulley.....
Yup....I know what a 'shiv' is....and as a journeyman machinist, I would never 'mate' something with that small of a bore .002" tight and .001" is plenty tight.IMO.....the sheave (aka pulley) is an interference fit on the shaft with out a key. A jaw puller pulling from the end of shaft ( actually reacting on the shaft end with the jaws around the sheave'pullimg groove). To put the sheave back on and positioned correctly, it is pressed on....with a 0,0015" - 0.002" interference fit. The alternator must be disassembled exposing the brush end of the shaft and brush end bearing...the wiring does not need to be removed, but this would be an excellent time to replace the drive end bearing (#6203SZ sealed both sides single row ball bearing...any brand...SKF, NTN, RBC, etc). Support the alternator assembly with the he brush end bearing's shaft on the pressing plate, and starting the drive end shaft and sheave facing the pressing ram, slowly start to press the sheave on the shaft, making sure it's square. Continue to press the sheave to the required depth as measured AND RECORDED b4 pulling the sheave off from the shaft end to the measured ID depth. The shaft absorbes the pressing forces not the aluminum housing or bearing. This way the pressing on dimension can be controlled rather than heating the sheave and trying to guess the exact position b4 it cools off.
BTW....in power transmission lingo, a pulley is used on a rubber belt type conveyor EITHER as a head pulley (drive end) or idler pulley (tail or idler end) of the conveyor with toughing rollers to support the moving belt along the length of the conveyor. Anyway......Just my thoughts and opinion of course.....
BOB RENTON
Exactly what I did. Rock Auto has the parts for rebuild pretty reasonable.IMO.....the sheave (aka pulley) is an interference fit on the shaft with out a key. A jaw puller pulling from the end of shaft ( actually reacting on the shaft end with the jaws around the sheave'pullimg groove). To put the sheave back on and positioned correctly, it is pressed on....with a 0,0015" - 0.002" interference fit. The alternator must be disassembled exposing the brush end of the shaft and brush end bearing...the wiring does not need to be removed, but this would be an excellent time to replace the drive end bearing (#6203SZ sealed both sides single row ball bearing...any brand...SKF, NTN, RBC, etc). Support the alternator assembly with the he brush end bearing's shaft on the pressing plate, and starting the drive end shaft and sheave facing the pressing ram, slowly start to press the sheave on the shaft, making sure it's square. Continue to press the sheave to the required depth as measured AND RECORDED b4 pulling the sheave off from the shaft end to the measured ID depth. The shaft absorbes the pressing forces not the aluminum housing or bearing. This way the pressing on dimension can be controlled rather than heating the sheave and trying to guess the exact position b4 it cools off.
BOB RENTON
