76mopar
I've been fighting electrical gremlins from time to time on my '76 Charger SE. It started about 5 years ago when it decided to leave me stranded in Virginia on my way to Bristol for a car show. Luckily I found a motel across from a Napa store that I was able to somewhat fix the car to get me home had to abandoned the show.
The problem is that the charging system goes out. At that time I changed the Alternator, Voltage regulator and even the battery (Needed a new one to have enough juice to get me home). But the system never charged. After I chased wires down I found the Field and Load Relay on the firewall must have went bad. Couldn't find a new one at any parts stores had to get one from a junkyard in Ohio. I even changed the regulator in the dash to be safe. Back working good but still leery of the cars dependability now. Chased all wires none were burnt or cut.
Fast forward a few years and now the Alternator went out again. So this time I just went with a one wire deal to by pass that relay. Seemed to work good but that alternator took a crap about a year later. Now this car doesn't get drove much in the mean time just sits in the garage on a battery tender to keep it fully charged. So last year I get a real Chrysler alternator and put everything back and all seems to be good now........
Until Last month when I started to notice that the Charging voltage is not where it should be running down the road its around 12.8 Volts. And when I use the blinkers the radio goes on and off as the blinkers blink, last week I found that when I use the wipers the radio goes on and off also. I've got a car show I'm wanting to go to in Indiana and need to get this figured out. The alternator is good cause when I ground the green wire it jumps in voltage to the battery. I'm gonna change voltage regulators tonight to see if that fixes the charging problem
Car is bone stock wiring has not been hacked on.
So my question to you is has anyone had this kind of problem before? Do you think the Field and Load Relay has gone to crap again? I'm at a loss. I would like to get this car to be dependable again. I love driving it. Funny thing is that the 2 '77 Doba's and the '77 Charger SE I have don't have the field and load relay so that makes this puzzle even harder. Can I bypass the relay, if so how?
I will post a picture of the relay tonight. I will post a picture of the wiring diagram also.
Sorry for the long drawn out post. Hopefully it makes sense.
Wiring diagram: http://www.auto-wiring-diagram.com/...l-wiring-diagram-of-1976-chrysler-cordoba.jpg
