Jeff_K
New Member
Brand new, never used, Chrysler 485hp small block crate engine.
We had planned to install this engine into a Dodge Street car project however due to health issues we decided to stop the project and sell the parts.
It was stored for some time so we had it internally inspected and it's in great condition. The outside did pick up some tarnish though.
*Built by Proformance Unlimited
*485 hp SB crate engine
*Mopar 408 ci - Chrysler 360 Block bored and honed w/ deck plate
*80psi cold Oil pressure
*Block has been decked
*4340 forged steel 4.00 stroke crankshaft
*Mains aligned
*10-1 compression ratio
*H-Beam bushed connecting rods (Eagle)
*High Performance rings hand filed to match application
*Performance Forged pistons
*Performance rod and main bearing
*Double roller timing set / Hydraulic Roller Lifters & Rockers
*High performance valve springs and retainers (to match camshaft)
*Aluminum Edelbrock cylinder heads & intake manifold
*Melling high volume oil pickup & oil pump
*Chrome moly push rods
*Aluminum timing cover
*Brass freeze plugs with oil galley kit installed
*Serpentine March Pully system w/ alternator & A/C compressor incl.
*Science Friction Billet Steel flywheel, SFI Quality 130t / 10.5"
$9,950 - OBO - pickup only - no trades
Located in Los Angeles, Ca 91343
*Mains aligned
