dart14
1969 coronet convertible 318 auto / standard original dash. I have removed the instrument cluster. When checking continuity on the circuit board, I get a continuity reading on any pin when checked at any light bulb connection or at the fuel gauge or temp gauge. Readings at the pin to gauges vary from 0 to approx 68 ohms, depending on the pin. Is it normal to get continuity from any pin to any connection (ie. hi beam indicator pin to temp gauge) ?
The reason the cluster is out is because the fuel gauge is not working. Good ground at fuel sender. Approx 60 ohms from sender with 4 gals in the tank. Sender was removed and checked and cylce was from approx 10 to 75 ohms. When grounding the sender wire to chassis, gauge did not move. 3 AA battery test on the gauge once cluster removed - gauge moved to 7/8 full so the gauge is good. Sender wire to harness connection at kick panel showed continuity. harness Connection to circuit board pin showed continuity so wiring is good.
Since temp gauge works OK, assume it is not the Dash voltage regulator - would like to pick a new solid state regulator at Carlisle coming up while the cluster is out to prevent future issues.
Not sure where to go next
