themechanic
Oklahoma is OK
- 2:16 PM
- Nov 11, 2012
- Moore, Oklahoma
Dennis, is that 23 C or F?
I had the EXACT problems installing their kit in a 1972 duster back in 2007. Guess they didn't fix much in that kit since. The two blue wires were the biggest whore of the install. Drove me nuts for a couple days trying to figure out.I'm installing a Classic Auto Air "Perfect Fit" system in '72 Dart. I know it's an A-body, but I feel like the experience is relevant.
1. The brackets for hanging the HVAC box under the cowl did not fit. Different from the pictures, didn't fit in the car. Tech support was no help. Sent pictures to them, no response. Ended up bending them to fit and making it work.
2. Instructions are terrible. Lots of missing information. Pictures from multiple cars, one of which is far from factory. Grainy black pictures of black cars in a dark engine bay are no help to anyone.
3. Heater core tubes on their box are the same size. Factory tubes are 5/8" and 3/4", so I had to use an adapter. If they would supply one- fine. But they didn't.
4. The temperature control cable is a full foot too long and the mode control cable is about 6" too short. I requested new cables of the appropriate length. No response.
5. The wiring and wiring diagram are terrible. I mean, if you have two wires that will cause the system to blow fuses if not hooked up correctly, DON'T MAKE THEM BOTH BLUE AND ATTACH THEM TO THE SAME SWITCH. Tech support did know exactly what was happening here when I called them.
6. The condensor "sandwiches" between the radiator and core support. It's just sandwiched in there! How hard would it be to bolt it to the factory locations (which is what I'm going to do) or the radiator bolts?
7. Their silly round "cover plate" that covers the blower hole in the firewall and lets the four HVAC box fittings into the engine bay would not fit the hoses on the box, and didn't even come close to lining up with the four factory mounting holes in the firewall. I had to bend two of the pipes to get them through the cover, and drill new holes to mount it.
Overall I'm highly disappointed. I chose this kit because of the reputation of the company and their support (which I had no doubt I would need). I've also seen it used several times. In my experience, the kit, service, and fitment are all severely sub-par. It's should be called a "Sorta Fits" system.
Maybe the B-body kit is different. Good luck if you try it.
