There's a regularly manufactured oval 6bbl air filter K&N makes for the Mopar oval air cleaner that is about 1½" taller IIRC than the paper one, and K&N has a special order oval filter that's even taller. Significantly more air flow, measured in real numbers, and definitely a factor for a hot 440 or stroker. Depending on how high the Indy ModMan intake puts me relative to my AMD N96 hood, and there's the possibility of me adding the appx ½" Nitrous Express spray plate between the center carb and intake (and 2 spacers under the other 2 to make them level, or 2 spray plates under the outboard carbs and a spacer under the center) I may well be faced with the same dilemma as before: Have the raised section of my hood custom built into a taller version and incorporate the N96 Air Grabber, or just go with the aftermarket (slightly taller) A12 lift off hood style air scoop, and know it all fits, costs less, and possibility functions better. I avoid driving in the rain whenever possible, I have A12 filter base, foam hood seal, and fiberglass air cleaner cover, all "new" in a box, or maybe take advantage of the drop built into my 70 6bbl base and make a hybrid A12 setup.
I LOVE the Air Grabber enough to have spent the money on the hood and even more to have it paint matched, and I have the N96 clamshell and some other components too, but before I buy the rest, I have to see where I wind up once the 572 is in place.
If I have to toss the Air Grabber, and my intake height becomes flexible, I'd be really tempted to try a 440-25 cross ram intake but with a 6bbl top. Then again, by the time I pay for everything that is going to cost me, I may be happy to be able to buy fuel for it. Lol.
