mgoblue9798
small block cam and lifters NEW IN BOX
$165 parts new in box save $50 off summit price
paypal ok you pay the fees
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,500-5,500
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:218
Duration at 050 inch Lift:218 int./218 exh.
Advertised Intake Duration:268
Advertised Exhaust Duration:268
Advertised Duration:268 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.454 exh.
Lobe Separation (degrees):110
Grind Number:CRS 268H-10
