Connector "pins" don't know the name of them
__Larsson____
12:41 AM
JONKOPING
So i'm having trouble finding these typ of connector "pins" or whatever you call em, it is the ones that is on the blinker and also the ignition wiring under the dash on the steering coloumn.
Are they available in the states?
Or do you have another way to connect the wires in a nice way?
It's been a very long time since I've been inside of a steering column but don't remember anything looking like that.....
The flat 7-pin connector for 68-70 cars (at least) use those pin connectors. Two different sizes....for the ignition, indicators and brake light circuits.
Got these on Amazon last year for my 69 Super Bee. There is a diagram that shows the sizes.
Molex Pin, Male & Female .093"... https://www.amazon.com/dp/B07V56PW33?ref=ppx_pop_mob_ap_share
But there are 2 different sizes in the ignition connector, is this the smaller one who also are in the blinker connector?
Not sure, I can check tomorrow. I purchased a new connector and wiring I think from Year One for my steering column.
.093 is the common size, used for T/S and most of the Ignition wires... The main power leads are bigger, around .139 I believe... Those are virtually impossible to find anymore... I got six of them eight or none years ago and they were hard to find then....
Dang it, thats the one i need most. Im thinking of like puting in a juntion box that the wire connects to instead.
We do have some in Sweden, but i can't buy em if i don't have an account and a company and then i need to buy a 100 pack of them each. We got 3 sizes, 2mm = 0,079" / 4mm = 0,157" / and 5mm = 0,197" I might be able to fit the 0,157" but it might be a bit tight.
I might go for a juntion box.
May want to consider a different type of connector, especially for the higher current ignition switch connections. The original Molex terminals are limited in their current handling capacity.
What size do they use today for the replacement parts? Like on the new OE wiring harness?
On the Ron Francis wiring kit, they use a packard type connector. I think it was 2 row by 4 (or 5?) uses the packard 46/48 terminals like used just about on the bulkhead connector.
I believe the M&H OE replacement wiring harness uses the original style molex connector.
BULLET Connector.
Now ya know why some hide from the conversation...lol
Bullet connectors.
