Cooling fan size
old guys rule
1:23 PM
Jacksonville, FL
Having trouble finding A7 blade fan at least 17 inches diameter. A little help? A clutch fan All Steel non Flex I only have 17 and 1/2 in to work with
Not sure what you're asking, you want a 17" fan as you only have 17-1/2" to work with? I don't know of any Mopar shroud w only 17-1/2" opening. If you are referring to the height of the core on the radiator, most of the factory 7 blade fans were 18" - 18-1/2" diameter. They are bigger than the actual core is tall, but they sit back about an inch from the radiator inside the shroud that is about 20" to 21" in diameter.
Been talking to him through a PM. He is looking for a fan and did start a wanted thread.
