340prostock
I have a 73 Satellite with a 318 2bbl (until I put my LD340 manifold and carb on it, I need it to run).
Symptoms, it stumbles of the line. I am assuming it is the accelerator pump is bad, also when it is cold it will only start with starting fluid, I can crank and pump the pedal and nothing, spray a bit of starting fluid in the breather opening and she fires right up.
I was told by the guy I bought it from that this may not be the original carb for the car. I have looked on Auto parts web sites and it looks like 73 is a one year only carb, is that correct ? would a 74 and up work ? is it different due to the unleaded started in 74 ? , I see for Carter numbers online that the carb kit works on 6316 ,6317, 6343, 6344.
so can anyone tell me what should be on it ? or does it mater as long as the carb kit fits ?
thanx
thanx
