Correct Carb for 1971
Erik70rt
6:06 PM
Jackson Twp, PA
What would be the correct carb for a 1971 Road Runner with a 383 and 4 spd and an air grabber? Car was built in Aug, 1970.
A 1971 Road Runner with a 383 with Air Grabber and four speed transmission, built in August of 1970 was originally equipped with a Holley R4734A four-barrel carburetor.
For all 1971 E-bodies and B-bodies with 383 high performance 4-barrel engines, the numbers are as follows:
1971 383 without fresh air, with manual transmission: Holley R4667A or R6191A
1971 383 without fresh air, with automatic transmission: Holley R4668A
1971 383 with fresh air, with manual transmission: Holley R4734A or R6193A
1971 383 with fresh air, with automatic transmission: Holley R4735A
Automatic cars have a distributor ground switch. Manual transmission cars have an idle speed solenoid which also has a ground switch on the plunger.
1971 383 without fresh air manual: Holley R4667A or R6191A
1971 383 without fresh air automatic: Holley R4668A
1971 383 with fresh air manual: Holley R4734A or R6193A
1971 383 with fresh air automatic: Holley R4735A
The 1971's with automatic AND Air conditioning also used the Holley R4668A, which also had an automatic thermostatic air bleed valve, to prevent hot soak condition at idle. I had a WP23N1A******* Dodge Charger 500....
BOB RENTON
